rickprice said:We have the wired ring floodlights with camera, for over a year. I would comment this:
They need WiFi to work - and a strong signal.
The resolution on a moving (5-10mph) vehicle is not good enough to see the number plate (unless the resolution and frame rate has changed since we bought ours).
You need an online subscription to save the footage (£5 per month).
The interface and other uses are excellent, though. They are easy as pie to set up (make sure you can reach the box when you set it up, you may need to press the button on the top).
I have an issue with the WiFi and I think if I bought again I am not sure I would go with ring, mainly for the resolution.
FZP said:If they are going to pinch your car, they're going to pinch it.
Porkaholic said:I would like to recommend this K-9 unit. Very robust intelligent system but susceptible to food bribes and easily distracted by cats and squirrels otherwise
very effective deterrent.
