Hopefully an easy question – do the dash knob/switches simply pull off to access the bulbs. Tried a little gentle pressure but don't want to damage expensive Porsche plastic.
Thanks.
Are you referring to the switches for fog lights and screen heater?
They don't pull off but instead you need to prise out the plastic disc that has the symbol on it. Be careful as they are delicate and easily scratched. Use a plastic tool known as a 'spudger' if possible. Bulbs are a push fit capless type. Take care to fit the disc back in the correct orientation or risk ridicule from the illuminati.
The cigar lighter does not have a bulb behind the disc.
Yes, it is the fogs & the screen heater. I have changed the bulb in the headlight switch & wondered if the others were the same fitting. I looked at a parts diagram & it looked like the sections outside the dash were separate parts, good job I did not keep pulling!
This now leads me to another question re the headlight switch. When illuminated mine shows scratches around the edge – can you get new inserts? I have seen them for the fogs & screen heater but not the headlight.
Thanks, the post-Christmas tinkering continues.
The fog / rear guard switches all unscrew. It's a lot easier to get the little disc with the symbol on it out with the knob out. When I did one of mine I used a mobile phone / Tablet kit which I got off the bay for £1.50. The kit for removing the battery for a phone or tablet, little plastic levers which don't mark or damage the disc.
I've tried to switch the headlamp bulb before with LED type but think I've managed to destroy the contacts.
Reverting back to the little wheat grain bulbs and still no light.
Is the illumination function fused? Nothing else seems affected.
I'm loath to replace the full switch for the sake of the damaged illumination function but annoyed as I believe trying to force the LED type in crossed the contacts and has destroyed the circuit deep in the switch.
