Hi All
I test drove an '06 C2 manual the other day. Everything seems to be pretty good with it but have a couple of queries / concerns:
1. After the test drive I opened up the oil cap and there seemed to be a milky residue (pic attached). Is this expected or is coolant mixing with the oil and if so is it a new air oil separator required?
2. The last major service had a customer advisory note stating that it requires front axle coolant pipes and front control arm needs replacing. How much should I budget for that and is it s job that requires immediate attention as I did shine a torch on the coolant pipes and there was no visible leak.
