The return of Marty Wild
Paul Ricard
- Joined
- 4 Nov 2016
- Messages
- 3,146
Recently did the 987 Airbox, 997 Throttle Body and IPD plenum mod on my 986, it is fair to say it hasn't gone well, so far..... after getting the car back together, she point blank refused to start unless we pulled the MAF. And without MAF she would idle, but soon as you asked for throttle she'd cut out.
Process from my ownership thread:
Getting the 986 airbox out and the 987 one in. This was major missions, ended up taking the intake mani off and loosening the associated fuel rail. Giving all seals a going over with Gummi as we went. We ended up chopping quite a lot of plastic off the A/B as we knew we would. You also need to glue up the hole that is revealed when you remove the sound baffle from the A/B.
Painstakingly then crafted a new intake pipe to connect to the the larger bore piping from the 987 MAF housing. Stupidly bought a reducer pipe that wasn't needed, happy accident though, as we then trimmed it into a much needed sleeve. We took some of the 986 MAF housing and shaped it to provide support under said sleeve to keep the pipes from collapsing. Eventually fitted the IPD plenum and 997 TB. Took real care getting everything back together again, nailing all the cable plugs, vacuum pipes, trying to get the injectors nicely seated etc. We do now have 987 sized intake all the way from the A/B with BMC filter all the way to the 997 TB.
Then started her up, runs like a complete dog, well I say runs, engine stops after not very long at all. Doesn't sound like an intake leak anywhere from previous experience. Runs without the MAF plugged in, but not well enough that we thought she could be driven. No amounts of TB resets would help her learn the new parts. As the MAF was an unknown from ebay, we then decided to replace it with another new 987 one and still no joy. Slightly better values through my cheapy BT dongle and free App but still no cigar.
Resident genius is leaning towards the car needing to be trailered to a tuners for the new parts to be mapped in. My basic OBD App sees no errors, and the MAF signal, for the short period the cars runs, suggests the DME is not seeing anywhere near enough airflow. Had been in contact with Wayne, he's gone quiet now though. Turns out RPM doesn't tune anymore, which is a real shame as they are close to Mill Hill where she resides currently.
Tried to get 'Mobile Porsche Specialist' out to run OBD, which they agreed to do, job in place for 9 days, then cancelled 24 hours before the appointment. Avoid those jokers!
Massive thanks to my mate's Dad for all his help on getting all the mods in.
Worth noting that unless you have done the 987 Engine Cover mod, you may struggle to fit the old fibreglass lid back on after you have put the larger plenum and TB in. See Raggy's thread on my next page to see what I mean!
Updated with pics.
Updated with pics.
