Been a while since I've updated this, things have slowly been ticking along. For one, went for a service at Cameron and got some pics, see below. On 3k ish miles on the engine now.
I've also figured out what's going on with the rev limiter kicking in too soon and the slight annoyance on transients. Turns out there's some noise on the crank VR signal - so datalogging at high rpm it's spiking a bit kicking in the rev limiter, and on and off throttle it's a little fuzzy. Not detectable on the rev counter, only datalogging. As annoying as this might be, I'm happy to have figured out what's going on. Interestingly maxxecu doesn't exhibit the high rpm issue so presumably has a more robust VR conditioner circuit than the factory dme, but it does suffer from the same noise on and off throttle.
Anyway, I tried changing the sensor, no luck. So reluctantly off came the gearbox to have a look at the flywheel and sensor interface. All looks good, but new stuck a new dmf in there while I had the box off. Car's still in bits so not had chance to test if I've fixed it or if more troubleshooting required. I contemplated a lightweight fw while in there but decided against it for driveability, noise, harmonics etc. Researching did make me realise the 997 3.8 has a harmonic balancer so I've bought one.
Making the best of having the gearbox off, I also bought a quaife ATB. I went for an ATB as have a blackline in a bmw and find it perfect for road use. Annoyingly I misinterpreted 'with flange retainers' on the quaife tech drawing and ended up with the diff for flanges with snap rings, not bolted. Quaife have been pretty unhelpful and I've not managed to find any cheap used ones so have decided to machine in a snap ring groove into my existing diff flanges. But porsche don't have any stock of snap rings and keep pushing the update date, so I've bought generic ones. Off to use a friend's lathe tomorrow to have a go at this, hopefully then can get it back on the road! That and I slightly damaged a carrier bearing removing it and so had to buy a replacement, and have a smidge more backlash than before, so am reshimming by 0.1mm to get it back to spec. I weighed the quaife vs the original, a 700g penalty for the quaife.
In the spirit of 'while there', I also acquired some pfc 350mm v1 front disks for £300, 9kg vs 11.9kg for the originals, so a handy 6kg saving and bolted right on with 10mm steel washers to space out the calipers. I also replaced the brake line under the car and the rear link pipes and acquired some brand new wheel arch splash guards cheaply.
Weight savings over factory now at approx 125kg.
Remaining on the list are a coolant pipe replacement at the front which has been weeping a little, and pondering what I can do exhaust-wise to get a better flow path and larger diameter manifold primaries and see if I can go significantly lighter than the 21kg in the backboxes (8kg for each box + 2.5kg for the brackets to hold to the engine).
