About time I updated this, been a bit busy with one thing or another but the 996 is ticking along nicely. This will probably be a bit of a mega update so will break it down into a few parts
Engine/tuning:
Had a few issues with obd flashing and bricking dmes, but have learnt both how to copy the data on to a new DME (so now have 2 working DMEs with my vehicle data) as well as how to bench flash them back into life.
I had the car rolling roaded today locally on dimsport rollers making 370bhp @ 7150rpm and a nice strong torque curve throughout, but the dyno wasn't really any good for porsches/rear engined cars. No fan over the back meant it was just heat soaking so I didn't do many runs, and the logging was bit limited despite me paying extra for it (no IAT, AFR was clearly not giving a reading until higher rpms) so I didn't want to tweak anything based on their readings. Having said all that, their wideband suggests that there's probably a bit more in there by richening up a smidge further and I'm running factory spark and cam timing, so there's probably a bit more in there through that. All in all a satisfactory result and I'm really happy that as expected there's a really strong torque curve and nice smooth delivery, but I feel there may be some more to come. The engine's only on 1k miles so am not going crazy. V happy that it was also running very clean on the dyno.
Besides this, I've made a bunch of other dme changes including:
-removing secondary air pump - I've never really liked how crammed in it is with x51 and the 997.2 airbox, so I decided it would make sense to remove it and clean up the engine bay. I just capped off the valve and disconnected the vacuum actuator so the valve always stays shut. By some careful tweaks of the dme, it now passes readiness (that's to say if you run the secondary injection short test in piwis, it passes), has no fault codes or anything – basically the dme expects airflow out of the pump is 0. It's a good amount quieter on cold start, not to mention removing 1.6kg over the rear of the car and getting rid of the pipe.
-removing the rear o2 sensor heating diagnosis so that there's no fault codes for the fact that they're currently removed to allow for the wideband lambda, but left them operational so I can plug them back in if I so choose.
-altering some of the temp variables so that stage 1 fan kicks in at 95.75c rather than 97c and stage 2 full speed fan at 99c rather than 102c, same for engine compartment fan, and I've reduced the hysteresis from 3 to 2 degrees. I'm not a fan of running a LTT for many reasons (so don't!) but the fans never come on anyway, nonetheless thought this was a good bit of extra protection against running hot.
-7,4k rev limit – 997 x51 runs 7,450 and I've ARP hardware on the crankcases and rod bolts etc, but I've kept it down a bit. The car is still making near peak power at 7,4k so ideally it could be set higher but I just don't need it and will never use it and would rather protect the engine.
The only other thing to report is I've had a bit of a play with a 9x7 dme to see whether I could get that to work as the 996 dme is still a bit grumpy on part load in places with 997 injectors (I'm working on it!), but it won't handshake with the M534 and I can't find how to or anyone who can immo off it, so without going down the rabbit hole of changing clocks and M534 I think it's a no go.
