Just about to board channel tunnel and have noticed both aren't working, no pump noise being heard. Yes there is plenty of liquid. Any tips? Do they share a relay/ fuse?
Jon
Pop the nearside headlamp out and get tap the pump while somebody operates the washer jets see if it fires into life. Mine packed in and I did this and it started working but has since stopped working again so just about to order a new one!
Worth checking with OPC as I recently got a replacement pump with plug (You may have to change the plug on the loom as the new pumps (996 pumps I believe) have different plug connections)) for about £40.
