WB Wheels ET51 on a NB Car
roocat
13 Jul 2017
92
Morning all,
I've been searching the forums about this. I'm looking at some wheels where the 19" rears are 11J ET51.
My current wheels are standard 11J ET67 which I was about to get lowered (techart) and put 15mm spacers on.
If I've worked it out correctly the new wheels would push out 16mm further than my current ones, so I wouldn't need to bother with spacers.
Problem I have is so many posts say this is fine 16mm vs 15mm is nothing, while other say don't do it, they'll stick out it'll look ridiculous etc etc.
So I wondered if anyone has done this and if so would the mind posting a picture so I can see what it looks like?. I've seen a few posts with people asking similar questions but few have come back saying they'd done it and posted a pic (from what I found anyway)
My car is a 997.2 C2S.
thanks and sorry for another wheel question :)
when I sold my gen1 NB I swapped the wheels over and fitted WB turbo 2 alloys and it looked fine with no spacers at all , I think there may be some debate about it due to what I found , if you swap the alloy over but leave the 305 tyres on it can look a bit wide but if you fit your 295 tyres on the WB alloy it sits better , lowering it will pull the camber in at the top even further. the other thing to consider is the sidewall profile of different tyres as some have a more rounded profile MPSS for e.g. whereas contis etc have a straighter squarer sidewall and bigger rim protector.
all these varients are I believe the reason for such a mixed review of putting WB alloys on a NB car. :thumb: :thumb:
cheers Phil, I was hoping to put 295 MPS4's on them so I may go for it :)
Before committing, it might be an idea to see if there are any forum WB owners in your local area that would be willing to do a test fit. It would certainly give a definitive answer. :thumb:
C.
C.
I think thats a spot on suggestion, if there are any but bear in mind if they are WB owners they will be running 305s on them so you wont get the right feel . ideally it would be someone with them fitted to a NB running 295s
Sorry these are the only pics I have of the swap over as you can see the turbo2s were on the 4S WB on the ramp and then put on my NB gen2 the tyres were MPS2 :thumb:
Photos of WB turbo alloys on my C2S fitted with Continental 295s. I wouldn't push it to 305s on mine... :thumb:
I suppose you'd be OK on 19x11s with the WB offset, but the 19x11.5s might be a challenge. On the other hand, if you lower it a tad, the tops of the wheels might align with the arches. You really want to avoid 'poke'.
The alternative is a bit of gentle rolling of the arches. 8)
thanks all for your advice.
addavies - are those wheels 11J ET51?
Yep. The same as these:
https://www.ebay.co.uk/itm/GENUINE-PORSCHE-911-997-TURBO-C4S-19-INCH-POLISHED-REAR-ALLOY-WHEEL-X1/302392889155?_trkparms=aid%3D555017%26algo%3DPL.CASSINI%26ao%3D2%26asc%3D20151005190540%26meid%3Db5f48efcff1141fdbf7b8f8695eaf3ad%26pid%3D100505%26rk%3D1%26rkt%3D1%26%26itm%3D302392889155&_trksid=p2045573.c100505.m3226[/url]
They will likely fit but they will ruin it. 20" is too big a look for 997. It is a small car.
124,625
1,442,218
49,060
pands
