I've changed mine a few times and reckon the best of the bunch is the 996 3 spoke wheel. It's the perfect size between the larger 4 spoke 993 whee and the smaller after market options. Initially I thought the smaller atiwe/raid wheels where a good option but once fitted I realised it makes the steering too heavy.
Unless your going RS spec there is not need to go for the airbag delete options.
After a good search I think you're right, the simplicity of fitment a huge plus too. Found a decent one on eBay, ill double check condition before installation. If its needing care ill pop it off to Royal steering wheels .. again recommended for their quality work on here.
I managed to get hold of a brand new techart wheel for mine a few years ago which is looks the same as the 993 wheel but is infact smaller and has a much nicer covering with thumb rests. I love it and it still looks period correct :thumbs:
996 Three Spoke is a good looking wheel and if you can find one with a leather airbag, even better. Definitely worth having the airbag should it ever be called upon... :wink:
That looks perfect. I love the look of the original wheel and think as time goes on it will become more better still. Nice that this one is so subtly different.
Jonttt is selling a RUF one isn't he? Might be a nice option?
My preference was the Raid 365mm (which is slightly bigger than RS but smaller than standard 993 memory) It is also thicker and the two combined made a massive positive difference. Retains an airbag option as well and look OEM (RUF used them on the 993 originally).
I've recently changed for a tequipment carbon 993 wheel to match my carbon interior but the Raid wheel is better IMHO.
NB size is everything and a few mm smaller diameter makes a massive difference in a steering wheels feel eg a 340mm raid wheel in a 993 would be too small IMHO and make the steering too heavy but a 365mm was perfect (and that was in a 4S which has heavier steering to start with)
Standard 993 wheel is around 380mm, the techart one I have is 370mm, but as pointed out that 10mm makes a massive difference in feeling and steering weight. I think the rs wheel is 355mm iirc
I had that wheel fitted to my 944 Turbo, great size and feel. however I don't really want to have to mess about with the boss and source a 964 surround tbf.
