Rocker Cover Gasket replacement
sday12
4 Oct 2010
577
Got the common rocker cover leak (again) any advice on completing the job?
I thought I'd get my guy to do it as the OPC price was prohibitively expensive.
If its the lower ones it's an easy DIY the top ones require a bit more work. When I did mine I replaced the gaskets and the bolts, all worked out well.
http://911uk.com/viewtopic.php?p=1350832&highlight=gaskets#1350832
http://911uk.com/viewtopic.php?p=1350523&highlight=gaskets#1350523
ATB :)
Depends what you mean by easy. The bolts behind the heat shield can be a begger to remove and the clutch vent pipe is worth a cus or two. But well worth the effort in money saved.
ATB :)
Hi Endoman,
I'm lucky that my car has never seen salty or gritted roads and has lived in a hot climate its entire life, so rusty bolts are not an issue with my car :D A squirt of WD40 has always worked for me. No clutch vent pipe as mine's a Tip. Bang on with the money saving :thumb:
ATB :)
124,629
1,442,272
49,073
Ors97
