LCA & Eccentric bolts
Drew1209
31 Aug 2016
261
Having phoned Porsche today about a few bits for my car the parts person advised that when I renew the coffin arms and fit new eccentric bolts I should be renewing the eccentric washers and nuts also, I had intended using the old ones with the new eccentric bolts.
Old one's are off the car no issue's although I did have to cut the eccentric bolts out.
Doe's this sound correct regarding the nut's and washers ?
I replaced all the bolts, washers and nuts when I did mine. They're cheap enough.
Word of warning though, the washers / captive disk things can cut into the aluminium side of the frame, making accurate alignment impossible without a bit of welding..
It's just good practice to replace old fixings.
Threads stretch, surfaces corrode etc.
I replaced mine.
124,625
1,442,221
49,060
pands
