Engine compartment lid stuck
Dave49
12 Oct 2008
52
Help.
My 930 has been laid up for a number of years and now I find I cannot open the engine compartment lid. The "t" shaped pull lever in the drivers door frame will not move, I do not want to apply too much force for fear of breaking it as it appears to be made of plastic .
I have sprayed WD40 into the crack on the lid but don't really know if I am getting close to the catch.
Any ideas? :?:
If you remove the trim under the rear window you will find the cable there. It goes along the shell of the car.
It could be a case of WD40 from inside the handle if not a set of pliers to pull the cable from inside the car will do the same as the handle to release the lid. This way you will not break the handle.
Thanks, I will try again tomorrow to see if the WD40 has done anything and if not I will try your pliers method.
124,626
1,442,234
49,070
janders365
