Whining Porsche............
Bit late with the advice here, sorry. All this is easy diy.
You have four fans on your 3.2, one for fresh air...bet it isnt that; two more down in each footwell, they come on with the hot air, run at two speeds and often screech on starting the heater (take the carpeted cover off, remove the fan, make sure its working, if so lubricate the bearings with WD40 or GT85...stick back in). If its knackered by a new one.
The other fan is in the engine bay, top left black thing with trunking going into it..This one should come on when ignition on, centre auto control to 3/4/5. I f it screaches you could remove and try to lubricate, but the bearings wear(so wiggle the shaft), its probably knackered and new required.
Many 3.2 do not benifit from all the blowers working properly hence an undeserved reputation for poor heating. If the fans and system work right you should get a jolly good blast of hot air up to the screen.
Lovely on a winters day, mmmmmmnnnn. :lol:
Adrian Crawford. 911secrets.com. performance2and4.co.uk
Migration info. Legacy thread was 10729
