Ocean996C4
- Joined
- 14 Jul 2016
- Messages
- 135
Good morning, I wonder if someone can help?
I'm replacing the CPS on a 964 with the later 996 part and I've opted to retain the connector on the car loom and swap the plug on the component.
The original 964 item has:
Thin brown
Thick brown
Thin white
Thick white
Conductive sleeving
The 996 component has:
Thick Brown
Thin white
Thick white
Wire with no sleeve
No conductuve sleeving
Obviously only 3 terminals on the plug itself, and it's a plastic non conductive connector.
Has anyone joined these and can you share the correct connections?
Barry
Thin brown
Thick brown
Thin white
Thick white
Conductive sleeving
Thick Brown
Thin white
Thick white
Wire with no sleeve
Barry
