Aircon Compressor clutch replacement?
Whitehorse
Nurburgring
23 Aug 2011
409
Hello all,
My A/C compressor clutch is grumbling and appears to have some play in the bearing. The compressor shaft is solid and the A/C is ice cold.
Can I replace the clutch or do I have to replace the entire Compressor, if I can where to get one from?
As an aside, my water pump bearing went recently and an idler, I wonder if a belt change in the past was incorrect? :?:
All and any help very much appreciated!
WH
Not sure if you can get an actual clutch sold separately, but I've had experience with one on a RAV4. Denso A/C compressor & it seems to be a hit or miss.
The original one failed, & it came off the shaft no problem. As I recall, it was a M6 pin holding the clutch on, & it simply slid off the shaft.
The second hand one I picked up from a breakers I couldn't budge. I ended up replacing the whole compressor & having to recharge the system.
I'll add a pic if i still have the old compressor & let you see how it looks.
124,625
1,442,221
49,060
pands
