Carrerascott
- Joined
- 28 Mar 2015
- Messages
- 137
997.1 C2S 2005 with PASM and 66k miles - used as a weekend car
Over the years I have always seemed to have had an issue with the ride etc. as the car always feels like it is crashing over every bump and not very compliant. With all of this comes the inevitable creaking and rattling of interior trim etc. been made worse, that is one of my pet hates. Getting to the point that I am just not enjoying the car!
The following has been done over the last 4.5 years and 7k miles whilst in my ownership starting with the oldest first to the most recent:
Front shock top strut mounts & bearings
Front inner rack ends
Rear lower control arms
Rear toe arms
New set of genuine Porsche alloys (as 2 where slightly buckled causing a vibration through the steering) and PS2 tyres
Front lower control arms
Front coil springs (1 had snapped)
Front shock stem washers & bump stops
Front anti-roll bar bushes
Also always generally had a 4-wheel alignment redone after any work and regularly check tire pressures
I think the only thing that hasn't been done is the front & rear shocks but never had an MoT advisory such as they were leaking or misting etc. Is this where I go next?
The latest issue now seems to be a knocking, clunking from the steering column or rack at low speed when turning left or applying a lot of lock. - Is this a common issue?
Car is going to my Indy in the next couple of weeks for its MoT so will get them to obviously check it over.
Any thoughts on the issues and what I should consider next?
thanks
Rear toe arms
thanks
