scarletboarder
- Joined
- 4 Aug 2016
- Messages
- 210
I've had a small coolant leak that I traced to the driver's side coolant return pipe. Having removed one end I promptly ordered both as the metal end of the pipes were corroded. Pipes arrived quickly from Design911.
The problem is that after removing the retaining clip neither pipe will come away from the next sections. They came out of the radiator end fine.
Any tips? I am already starting to damage the upper pipe metal connector. The bottom one is plastic. I've actually cut away the upper pipe to aid removal but its stuck fast.
