X911
- Joined
- 7 Oct 2021
- Messages
- 131
Hi all
First post although Ive been following the forums for some time now.
Have just become the owner of a 2003 C4S in Artic Silver, will upload some pics when I get an opportunity.
First modification was to install the PCCM Plus which I must say is a fantastic addition and really brings the car into the 21st Century. The car came with PCM2 and MOST with Bose speakers.
The install went very smoothly and took me perhaps a couple of hours until I got to the radio part of the install. I had the DAB box wired up but was only getting limited FM stations and no DAB. Consulted the forums and figured out that I needed to bypass the Diversity Control Module and the windscreen antenna amplifier. Both these parts caused me by far the most difficulty of the entire install ( and I opted to install the microphone in the factory location which meant taking out the entire instrument cluster).
I got the first connector (the double connector) out of the Diversity Control Module in the passenger footwell, however, the single connector was much more difficult to access and I must have spent 45 minutes trying to wrestle it out of its connector. Eventually I managed it. I connected one of the double connectors to the single one using the supplied blue cable.
Moved on to the windscreen antenna amplifier and similar problem there, the connecter (I removed the bottom one which I understand is the main antenna) simply wouldn't shift out of the holder! Again, eventually managed to get it free and connect up the by pass cable supplied with PCCM Plus. I connected the gold end of the supplied connector to the mustard/yellow coloured connector on the windscreen antenna amplifier and the grounded it using one of the two screws that secure it to the body of the vehicle. With that, the install was complete, or so i thought! c:
I am still getting limited FM and DAB stations. Sometimes I get a decent sized list of DAB+ stations (it still seem to be missing the BBC stations on DAB+) but then it drops out again. When I can get a list of stations up the audio quality is poor with quite prominent static noise behind the main audio from the station.
Anyone had similar issues and managed to resolve or have any ideas what the issue might be?
I am sure that I have installed everything correctly (having followed multiple forum threads and the dealer instructions) but clearly something isnt right. Only thought I have is that I could try connecting to the other connector on the windscreen antenna amplifier (the top one which I believe is the diversity?) but no idea if this is the problem, just simply guessing.
Any help here would be much appreciated!
Danny
Danny
