Phew! A marathon Saturday we had there.
13 hour stint (9am - 10pm) for me and Craig, so massive thanks to him as always.
Although we had an hour for lunch and an hour for a shakedown drive at teatime. Still a looong day.
We had a surprising amount of bother getting the system bled, but got there in the end.
I didn't take that many pictures actually as it's been covered before by myself and others and we were in the zone. :grin:
Certainly the pictures make it look like a much quicker job than it is, but that's always the case eh.
First job was to assemble the rad packs.
During the strip down it was clear the fan resistor clips were shot.
We couldn't find them on the PET and guess they must only come as part of complete new brackets.
Luckily the ones that hold the small water pipe are the same diameter (or very close) so I ordered double of those.
Rusted clip -
But these fit -
Fitted -
There was also a rear cover missing from the fan that had a new resistor fitted at Autostore prior to collection.
I'm obviously not implying they lost it but it would have been nice if they'd have fitted one once they knew it was missing. They're only £17 after all. :roll:
£70 really doesn't go far when it comes to Porsche bits.
Pipes scrubbed out to remove any shotblast from the powder coating. Ready to fit -
Rads and condensers built up onto brackets -
Centre rad and bracket assembled. Centre rad has a few impact marks from stones but nothing that affects its function, hence we reused it -
Fitted -
Passenger side plumbed in and complete -
Drivers side plumbed in and complete -
The eagle eyed amongst you will spot my rear fan cowls aren't present. I can only guess they've been ditched to aid cooling but I may source and fit some at a later date.
I did get O rings with the eBay condensers but Jamie left me 4 of the ones he fits in my ashtray at service time. Good lad. -
Once everything was built up we moved the car outside.
I gave the condensers a quick coating of ACF50. They'll still look rubbish after 1000 miles I bet.
Then we started filling the system and trying to get all the air out. This was easier said than done.
No point whinging about it as it's just one of those jobs, but eventually the rads and all pipes got hot etc as they should.
Plenty of info online but the short version is filler cap off, back end in the air, run engine with interior heater on full, keeping an eye on gauge. Once at 80 ish degrees rev up to a couple of thousand revs until thermostat opens. Put filler cap on before pressure builds and once you feel all rads getting hot.
We then checked for any leaks, topped coolant up and got ready to go for a drive.
Final jobs before going were to fit the arch liners to stop all the nice new parts getting filthy straight away -
Then it was upper ducts back on -
Finally it was the lower brake ducts.
My car still wore its large original ducts (dated '03), but they were tired and rattled around on the lower arms where they clip on.
New ones are £140 pair! Yep that's right, so I fitted the 997 GT3 items, which are less than £20 for 4, 2x front and 2x rear. They're a bit smaller but I'm sure they'll be fine and they fit nicely which is the main thing.
Old vs new -
Fitted left -
Fitted right -
I actually posted pics of both sides incase anyone wants the part numbers but I may as well list them below really. They fit Carreras as well and are a worthwhile mod. :wink:
Part numbers and prices for above -
997GT3 Front Ducts - £2.18 each plus vat
997.341.483.92
997.341.484.92.
997GT3 Rear Ducts - £6.30 each plus vat
997.331.487.92
997.331.488.92
We then headed out for a decent drive, stopping every few miles for checking/topping up the coolant.
With that done, back at home (it was 7pm by this time) we turned our attention to the front coffin arms in preparation for an alignment.
We removed these shims and old nuts -
Then fitted spacers (I had to grind a flat on for clearance) to take up the extra thread length left by the shims. K-nuts used to help with access.
Also it turned out we could squeeze 13mm nuts on the ends so a Nyloc was added behind each K-nut for good measure.
Of course removing 12mm from the track meant the wheels now towed out massively so Craig adjusted the track rod ends by eye, to get things a bit straighter.
As I've said it was 10pm by the time we got cleared up and got all the tools put away etc.
So on Monday I rang to book an alignment but I can't get it in until next Monday. I really want to use the car a bit this week to get some miles on it.
I'm having the air-con regassed this afternoon so I may pop into my local tyre place nearby and just get the front tracking set, so I'm not ripping my tyres off until next Monday.
That's about it, although I did have a tinker on on Sunday at a more leisurely pace.
Thanks for reading. :thumb:
