Boring post alert, sorry.
So Craig popped up last Saturday and we had a few hours on the car, carrying out some very similar jobs that we did to the C2 when I bought it. Boring stuff like battery charger lead fitted, etc.
I've mentioned on my threads before that I hate LED bulbs in cars that didn't have them as standard. Well typically a previous owner of my car had swapped every bulb for cheapie eBay LEDs.
They give off a horrible bluey white light and one or two weren't even working.
So first job was to ditch them all and fit original style ones for a healthy old skool yellow glow. :grin:
That includes front luggage compartment and engine lid lights as well.
Much better.
After that I removed some of the tacky stickers.
I'll be removing some of the side window ones too.
Then it was onto stripping out the interior for a couple of reasons. Firstly to chase one or two minor rattles (I just can't live with interior rattles) and secondly to provide access for a good clean, in particular the rear windows, which are a nightmare to get to with the cage in and I also want to wet vac the carpets and treat all the leather surfaces.
So it was out with cage and seats.
Leaving us with this.
The first job was an easy one. Sorting the worst rattle, which still wasn't bad to be honest, just a metallic buzzing from the rear shelf area. I had an idea what it would be and it was exactly that.
Basically the metal trays the ECUs mount to obviously had to be accessed for the remap in the past. The two edges of the shelves were vibrating together where there wasn't a fixing. We just disassembled and reassembled a bit more thoroughly.
So we removed the carpet section and inspected the ECU shelf.
One other thing that could have caused a rattle (although the main one was definitely the metal shelves) were the 2 empty relay sockets that were rattling around in the housing.
We added a cable tie to cure that.
Then I gave things a quick wipe down with some quick detailer before reassembling it.
As I say we built it back up carefully and I'm pretty sure it'll be cured now.
I also had a tiny buzz from the passenger door area. We stripped the door card off but couldn't find anything obvious.
There wasn't even a snapped clip or anything.
I had some new anti rattle clips but decided to just take the foam washers off them and fit them to the Porsche clips as they were perfect.
Kept these as they're original -
Used the washers off these for good measure -
We didn't go into the door as it's still factory fresh with the membrane having never been disturbed, so we left it alone.
The buzz was minor anyway so I'll see what it's like when I next use the car.
Another source of rattles could be the comfort seat wiring plugs which were just lying loose under each seat. I'll wrap these up and tape them to the floor before refitting the seats.
I'll crack on with the interior clean next weekend.
One pleasant surprise was that when we removed the rear speakers to take out the rear door cards, we were greeted by these -
Exactly the speakers I was going to buy for the car in time for my roadtrip.
Mind you they still sound pretty poor. No bass at all. To be expected from 4 inch drivers I suppose. I'm not going to add an amp and subs though. It's against the ethos of the car and I will only listen to music on my trip. It's mainly for Mrs Marky. Whenever I'm out for a blast the stereo is never on.
One more small job was to trim an area of plastic sill trim away. When JZM fitted the cage they left the trim really tight fitting around the bottom of the cage. That's great in theory but there isn't enough carpet to follow that U-shaped profile, so what happens is the sill carpet pulls forward to leave a gap where it meets the rear section in the rear foot wells.
We did this when fitting Craig's cage so it was a quick job.
Here's how it was when we stripped it.
Then after a bit of trimming with the Dremel.
Not the prettiest but you don't see it once the carpet is down and it actually makes the things you do see look much better.
No finished pics obviously as it's still in bits.
So once I've cleaned the interior I'll fit it all back together. I was going to leave the cage out as I'll want it out for luggage space for my trip but I think I'll refit it and take it back out before I go in a couple of months.
I may well fit different seats for the trip too. Now I know there's electric under there I can use my old C2 sports seats that recline if I want.
Anyway, all pretty mundane but as ever I'll record it here anyway. :wink:
