pietrzj
- Joined
- 19 Mar 2014
- Messages
- 309
I have a few issues with my guages and wondered if anyone has any advice on how to fix...
Oil Pressure Guage
Most of the time this works fine, but occassionally it drops to zero. Nothing a good tap on the glass doesn't fix, but I can't gaurantee this will work everytime and the novelty of pretending I am flying a WW1 biplane is wearing off, so I wondered if anyone new of a repairer or if they have fixed it themselves.
Oil Level Guage
I have never been convinced this reads correctly and even though the oil is 3/4 the way up the dipstick, it bearly sits above the orange section. I disconnected the sensor (RHS engine bay) and the gauge shoots to full, so the sensor works and its not the guage, but can the sensor in the oil tank be adjusted to "calibrate" in line with the dip stick? Anyone else got this problem or have fixed it? Last resort will be to replace the level sensor in the tank, but are there resistor readings I could take to prove it really is a duff sensor. And yes, I am reading the guage with the engine warm, idling and on level ground - which in itself is nuts as if its warm you would have though the oil is flowing around the front cooler and the level would go down not up.
Misty rev couinter glass
Last one in this thread. The back of the glass needs a good clean as it gets condensation mist in it on some cold mornings. The answer I think is to remove the guage and then the glass to clean it. Any tips on the best way to do this (luckily I have a steering wheel spacer, so I hope I will not have to remove the steering wheel to get it out).
TIA
Oil Pressure Guage
Oil Level Guage
TIA
