I will apologise in advance if you have seen this post on other forums.
This issue is causing sleepless nights, and it seems no one has the same actual issue and answer.
I have a 997.2 2011 C4S
Has anyone had / heard of an issue where at 2300 to 3000RPM all 6 cylinders misfire? If so what's the remedy as it's an issue which at the moment can't be resolved on 5 vehicles that I know about, including my 911.
2 x 911
2 x Boxsters
1 x Caymen
All cars have gone in for a service and mine went in for a squeaking water pump change and slight oil leak.
Looking for any relevant answers from the obvious to the guru stuff.
So far,,,,, All plugs and coil packs changed, HP fuel pump, solenoids, fuel drained out and new fuel in, reset the adaptions,
TIA[/b]
2 x 911
2 x Boxsters
1 x Caymen
TIA[/b]
