Hi all,
recently bought a 996 C4S and the tinkering/adjusting has begun.
I have a few questions though before I start in on trying to dismantle some little bits and hope some of you kind folk can help...
1. I have a glovebox rattle which I strongly suspect is coming from inside the latch. Naturally, I want to fix this, but how do you get into it? On the inside of the lid I can see lots of little 'bumps' covered by the felt like material. Are these screws / torx / pop rivets that all need to be undone to get access?
2. I have the non Bose PCM1 which is causing me some issues. The version I have has the CD multi changer in the frunk, then the interior goes (from top) air vent / cup holder / double din head unit / nav disc drive / heater controls.
Several issues with this as follows
- the buttons on the left and right on the double din don't illuminate with car lights on.
- the head unit tells me no CD is present even though I've put two in the changer (and made sure they're the right way up).
- the nav doesn't work. The drive wirrs away but it gives me the dreaded 'disc upside down' error.
Is there anything simple I can do to fix any of these before starting to rip things out? (maybe a reset or fuses to check?)
Lastly, assuming the head unit is just buggered are there any recommendations anyone can give as a 'cheap' replacement. I would want it to be plug and play, with no soldering or splicing of wires - just a few electrical blocks to undo and reattach. My must haves include bluetooth and USB, and I need to retain the cupholder and don't want anything 'blingy', more in keeping with the underatated nature of the interior as it currently is.
Many thanks for taking the time to read all that, and I appreciate any help or advice you can give
Michael
Michael
