Makes clutch use up to 30% lighter than the standard clutch slave cylinder. Please note, you will need to swap over the bleed valve, spring, spring plate, washer, snap ring & rubber boot from your old unit. Also for 5 speed 930 turbos, not for 965 turbos or 993 turbos.
Surplus to requirements now. Brand new and still in the package. £170 new will take £140.
Baz
Baz
