95 to 98 ron fuel adaptation time
Nordschleife
6 Mar 2014
22,188
If the DME has detected knock sensor readings (from running on 95 ron) and there for adapted itself to run retarded, how long does it take to revert back to the standard 98 ron map once if doesn't detect any pinking?
I've read in the past it takes a couple of fill ups of 98 ron, but does anyone have a more specific time frame?
Alex, it maybe done sooner if this is true;
The DME can "learn" the fuel grade (and atmospheric fuelling effects), so if you are planning on using a higher grade than in the last tankful, do a reset for immediate effect (rather than waiting for up to half a tank to passive reset).
DME reset is via key, Throttle Body reset is via key
Reset via key requires turning the key to ignition "1" (the position when all the lights are on on the dash) and leaving it for 60+ secs (DO NOT TOUCH THE THROTTLE PEDAL), then switch off for 10+ secs and you should be able to hear a few clicks and whirs from the engine bay as it recalibrates the adaption values.
Adaption must be performed when ambient temps are > 10°C
Extract from a GT4 post on an historic multi page fuel thread.
http://www.911uk.com/viewtopic.php?t=85897
I thought that was only relevant for the Bosch DME that was released on the 3.6 996 and newer (according to Adrian what's his face guide).
Yep, forgetting you have the earlier model.
Whilst digging around I saw mention a couple of times that all that was required was half a tank for recalibration, but couldn't swear that it was the 996.1 being referred to.
......and I've been no help at all. :coat:
I'm with infrasilver with this - the knock sensor is part of the engine management system and therefore not 'learned' or adjusted over time.
Put it another way, if it took 'tankfulls' for the DME to adjust, putting inferior fuel in would lead to knocking for a tankful or so, and I have not experienced this. On trips through Europe it is often difficult to get 98ron fuel, so when I put in 95 E10, there is no knocking detected at all - though I do notice that the car runs at a slightly higher temperature.
So I think adjustment is immediate and continuous.
There are no long term ignition trim tables.
Essentially, the knock is live monitored with a feedback loop that retards the ignition if knock is detected, then the ignition is progressively advanced over a set number of ignition events until knock is detected again, and so on..
I can't remember last time I put 95 in. Reason I was asking is cos my bank 1 solenoid was sometimes stuck with the cams advanced causing lumpy tickover and no doubt a loss in low end torque. My mechanic reckoned this would cause the engine to pink when advanced at low revs.......resulting then in the potential for the DME to think it was running on 95 ron and adapt to it.
So I was then wondering how, what and when the DME would adapt.
With your particular fault then the car would adapt as best as it could with knock and lambda sensors being the main ones ..
It will constantly try to adjust the timing on each cylinder to keep it at optimum and it will use the lambda sensors to maintain the correct fuel to air ratio .. the car can only do so much though so a lumpy tick over is the end result .
With newer model cars they have more sensors which are faster and the cars adapt pretty dam well to a fault .. not uncommon for me to see a car that runs and drives perfectly but has at least 1 failed sensor on it or indeed an air leak .
Wow! :eek:
That's amazing stuff! Glad I asked the question now.
Don't you just love science and technology :worship:
You also have short term and long term fuel adaptions .
Long term .. say a small vacuum pipe was leaking .. the car would continually see this on the lambda sensors and would slowly adjust the fueling to compensate for this .. as the leak got worse it would continually adapt to this ... upto a point .. the car can only do so much , when outside limits then it flags a fault code .
long term is for wear and tear basically .
This is done at lidle ... we call this Rkat and most times there is a problem then the long term adjustments recorded in this give us an indication of a fault ... from the readings its either running rich or lean .
Mid rev range and its Frao .
High rev range and its Frau .. i think i have got these two the correct way around .
Basically you never really see much adaption in these ranges..
Short term fueling adjustment is mainly on more modern cars ..
Say someone left the oil cap loose .. thats a big change to the mixture in a short space of time so the car rapidly adjusts for this and its a live reading so i can see if the car is running rich or lean straight away ... but its 997 onwards really im afraid .
The car compensates by increaseing or decreasing the injector duration .. it gives each cyl more or less fuel based on the above .
knock sensor and it adjusts the timing which can also be used for the above .. anything that gives correct lambda is basically the key .
Its also very good for the save the planet stuff .. slightly out of lambda signifcantly increases the output of NOx and thats bad for the planet .
My short term fuel trims were up and down like a brides nightie. Bank 1 was constantly trying to compensate something not being right and always in minus figures whilst bank 2 in positive.
Now the solenoid has been done they're nice and balanced.
Yup .. the issue you had was difficult for the car to compensate for .. intermitant faults are always the worst .. for us and the car !
You could already see the problem was on bank 1 though .. thats usefull when diagnoseing .. you then think , what could effect an entire bank ?
Theres not much and valve timing is pretty much it in a normal world so thats the area you work on .
As the cars have evolved then the adaptions to faults .. the fault codes etc have become far better ..
An example ive mentioned before ..
996 .. high lift tappet fault .. not your car .. no fault code.
997 .. high lift tappet fault .. fault code for a single bank of misfires and sometimes lambda sensors swopped .
991 .. high lift tappet fault .. fault code for this but it doesnt know which bank ..
The cars get better all the time , wont be long before the car tells me what to replace !
124,625
1,442,188
49,057
VeeRacer
