2 single turbo conversion
NedHan79
8 Nov 2018
1,096
Has anyone here ever went down the single turbo route? Either professionally bought or diy?
I find the idea very interesting and reasonably simply to manufacture though the mapping obviously would need proper professional attention.
I know everyone will just say you should've bought a turbo and the engines not strong enough but humour me.
There's big money kits online but what are the options?
Make some pipe work and find a suitably sized turbo. Likely go the water to air intercooler, sort the oil feed depending on where the turbos mounted. Then look at afm's And what ever else crops up along with extra cooling for the water. Ecu choice is another but I know a mapper who would be keen to get at it.
Any ideas?
Supercharging kits are readily available and much simpler/better IMHO :grin:
Yes but they're mega money. I've no real intention to do anything on this but I tend to overthink things :?
Typically you go to a single large turbo for making big power - it's less convenient to package than two smaller ones, but if you're drag racing then who cares about packaging, you'll find somewhere to put whatever you need.
I suspect that two small turbos would push right past what the stock M96 can accept in terms of boost pressure before detonating like crazy and then putting a rod through the block, so in order to need a large single turbo you'd need to drop the compression ratio to ~8.5:1, which means pistons and rods.
Maybe if you converted the entire fuel system to methanol with the significant increase in octane that that would bring, but again - time and trouble to do that.
I think you'd get more bang for your buck from dropping weight out of a C2 than you would either turbo or supercharging it, especially as forced induction is likely to dramatically increase the heat that the stock cooling system is trying to deal with, which would likely mean the head on bank one taking a quick trip to cracksville.
Yeah I'm well aware of the bigger problems involved with internals but it was more the idea of knocking up some pipe work and single turbo to be as cheap as possible.
I love the idea of an ls v8 but it's supposed to run into mega bucks though some have claimed to do it for $4000 usd. If I thought I'd get good money for the 3.4 I'd have it away and take a stab at it but it'd take serious money.
Trying to cram in a couple of turbos also wouldn't be easy
On a slightly different note, does anyone drag a 911 as its sole purpose?
There are loads of 911 Turbos that have been developed as drag cars.
On the subject of turboing a C2, adding two turbos to it would not mean instant detonation issues. Poor engine management is what causes that. There are plenty of high compression turbo engines out there. The M96 head gaskets are renowned for being pretty strong, so can probably take a few PSI of boost. The weak point will almost certainly be the big end and crankshaft bearings, which don't last brilliantly even on a non-turboed M96.
The way to do it would be to figure out the plumbing side of things, then set up a new, programmable ECU, such as an Emerald or a Megasquirt. There would be problems to solve in terms of getting all the sensors and the Variocam stuff to work with the new ECU, but this wouldn't be breaking new ground, indeed, I think that Mistercorn on here is using an aftermarket ECU with his C4 project. You would probably also need slightly bigger injectors. Getting the instruments all working properly would also take some serious expertise and would probably be the hardest part of the systems side of the project. For cooling you could get custom made thicker cored ali radiators to go in the standard locations, and you could use an air/water intercooler set up, cooled by a central third radiator, which is a commonly available upgrade kit.
I'm sure you could turn the boost up to 6-9 PSI and still have a degree of reliability, provided the bearings I mentioned earlier are fresh.
I think the reason that people don't go to all this trouble is that by the time you've done all that, you'll have a 911 with a turbo on it, that's probably a bit less powerful than an original 911 Turbo, is a bit more fragile, and probably cost about as much, probably more so when you factor in the hundreds of hours of effort making it all work.
My point is this: Yes you absolutely could turbo convert a C2 and make it work and have a degree of reliability, but I don't think there is much point.
All valid points Martin.
The management sides not a major issue as I've been there before and have a good man to sort that end.
I think the only real way to more hp is to go the ls route. I deep in welding the sills up atm. Rather than patch them I've cut most of them out. Probably have to do the arches as well. Since I'm going to a bit of trouble to prolong its life, I'm looking more at a little more fun. The engines coming out so I'll get a nosey round it. I love the idea of the v8 but couldn't stomach the cost.
But if the 3.4 was going to fetch a few quid then that's a different story
I don't see any point. For me, the NA engine is all about throttle response and revs. Better concentrating on those aspects and making the engine feel more 'alive' than in putting a turbo on it. That said, it would be a fun project. Lower the compression a bit, stronger rods and bolts, custom manifold and exhaust.
On the early cars the instruments are basically dumb.10v square wave for vehicle and road speed. Standard NTC sensors for temperature. They might well be CAN bus based on the later cars, but I have the data format for that, so converting an aftermarket ECU serial or CAN output to the format the car wants to see is not beyond the wit of man. I wouldn't want to get in to talking with tiptronic modules or PDK though. Right. Whose in, when do we start? :grin:
Personally (owning a car with a 5.4 litre V8) I'd rather put the money that an LS conversion would cost into the M96 - you'd end up with a very robust, very powerful flat six.
A quote attributed to Greg Brown from Precision Motor Werks, Anaheim, CA sums it up well, "What part of Porsche Racing did you think is going to be cheap, is it the the Porsche part, or is it the Racing part?"
I think you'll find your 'big horsepower Turbo'ed M96" brief could easily be substituted for 'Porsche Racing" in the above statement ...
I can think of few Porsche engines worse suited to your proposed brief.
I'm a great advocate of the journey being more interesting/fun than the destination, but this takes masochistic behaviour to a whole new level !!
I look forward to hearing your trials and tribulations as you navigate your way along this boulder strewn path ...
Slippydiff that's sounds about right. It would end up mega money.
I'm quite happy to work at my own car though I could do with more space and a ramp. My garage is pretty tight but I can appreciate some people are doing it all on the street. :eek:
Once your at a certain level of performance everything is expensive but I see stuff for these cars, and although I can see the engineering and skill in the parts, the prices are eye watering. Most people buying a 996 today are buying on a budget and by my thinking, there should be a budget market for upgrades. Not everything has to be thousands.
I have got some great tips and ideas on here. There's always a way round if your smart enough :?:
124,625
1,442,225
49,066
Mike 964 speedster
