While reading through Flyingelburro`s interesting thread here on 911UK, the pic he posted of his 997.1 4S that included a section of his exhaust attracted my attention, and I hope that he does not mind me re-posting it on this grumble about the quality of the fixings Porsche uses on their exhausts with whatever cost and consequences that might create in time for their customers..?
I have read and watched vids on the necessity to make use of a specialist jig to assist drilling corroded and damaged bolts out of the heads of 911`s when the manifold(s) might require removal. It seems to be accepted that these fixings will just break away in some cases, and expectations on exhaust fixings elsewhere are likely to be much the same if not worse...?
I do not remember the stats though I think it may be possible that perhaps as many of 80% of Porsches ever produced still exist in the hands of their owners, and Porsche also seem to be in the process of perhaps catering for their past production as opposed to leaving the owners to rely on specialist suppliers, as they may well have done over many years...?
Back to grumbling... Knowing the likely longevity of their cars as the result of their owners pride in maintaining them, I would be inclined to think that Porsche could if not should use more suitable materials (?) for the exhaust fixings.
I suspect in this group of Porsche enthusiasts there will be a fair smattering of mechanics, professional engineers and metallurgists who might care to share their materials knowledge, on this subject, which would be much appreciated.
I have also read on the forum where someone made available alternative supplies of 911 manifold to head bolts in titanium or some such metal, how well that might have worked out in time I have no idea,
Some time back before I bought my C4S and having read of this exhaust fixing corrosion issue, I had a go at loosening a couple of the exhaust fixings on my old crate, which I have owned for 20 years, it has an alloy V8 engine, on which the stainless bolts holding the mild steel manifold to the alloy head loosened without issue. Also in the last year or so I required to replace a section of exhaust on the old crate, on which the fixings have been undisturbed during my ownership, and again the stainless steel nuts and bolts simply unscrewed without fuss or bother, so much so that I re-used these fixings along with their original spring and plain washers to hold the new section of exhaust as can be seen in the pic.
I have no doubt that the 911 engine and exhaust may well be more exposed to being showered with water than the engine bay of my old crate, and that the exhaust temps may be a fair bit higher on on the 996/7/and 91, which may have a bearing on material choices..?
The exhaust flange holding the section of exhaust that I replaced on my old V8, is located under the front wing and very close to the wheel, so likely to be sprayed with whatever road grime exists, I have used the old thing in the Winter on occasion even with snow and grit on the road over the years
Form the images below compare if you will, the difference in the fixings from both the cyl head and the underwing exhaust flange on my old crate, against the Porsche fixings on one of the flanges of my now 9 year old 991, and those of the 997.1.
Looking at the condition of the exhaust on the 997.1, let alone the later 991.1 it can be seen/imagined that the fixings seem to corrode to the degree of possible failure perhaps some time before the rest of the system...?
I am sure I have read on this forum that one owner reckons that OE fixings should be replaced every four years when being serviced, in an attempt to avoid complications should the exhaust or part thereof require removal ..?
Any thoughts..?
Any thoughts..?
