Shaoxter said:
Well a pretty unanimous verdict then, and to be honest I prefer the standard look too. But one standard rear light is £520 whereas the clear ones on the tequipment site is £960 fitted :?:
GT4 said:
So just sort the vents on the one you have and save a fortune and have a better looking car.
Got a link for this?
There are two main problems with the LED tail lamps:
1) They run cool (nothing you can do about this)
2) They are inadequately vented (no air flow)
The first point is due to the efficient LED bulbs, on a halogen set up even as litle as 10 mins on tail lamp use will warm the lamps above ambient and evaporate and high moisture air (and this desiccation process is iterative - ie used often enough, the air inside will get drier and drier).
The second is the lamps are still designed as if they vent hot moist air from a halogen setup, and hence the vents are high.
The actual solution is two fold: low and through flow.
The high level vents not only are useless to liquid water escape, but they allow no through flow (think of a closed plastic water bottle you make a single small hole anywhere - top or bottom - the water basically goes nowhere until you have a pair: lower to release liquid, upper to allow in gas)
So firstly check the OEM rubber vent tubes and the vents themselves are clear, then (with the lamps off the car), carefully drill a 1-3mm hole at each lowest corner - ie lowest moulding points left and right of the lamp midpoint.
Although you must do this off the car, remember to take account of the orientation/lean the lamps have when fitted when you ascertain the lowest point (no gain from drilling holes in what appears to be lowest when they are sitting on your kitchen worktop, only to find that it isn't the lowest point when the lamps are actually in place)
Use some "stop" or collar on the drill bit so you only drill through the 1-2mm ish plastic - NOT into the guts of the lamp!
Now the condensed water can escape.
