Wheel Arch Stone chip protection film?
Just had a little paintwork done on mine for this very reason (stone chip/rash) so will give this a go, would be good to keep it tidy around the arches :thumb:
I've just had my rear pu painted so will try a set of those too.
I had a set of 944 clear front wing protectors on before, they didn't fit great but did a job, these look like a better solution.
OK - reinstated the photos using Imgur.com (been meaning to do that for a while), so Cableguy's link now shows the pics.
Those eBay films look a bit odd in the diagrams? Almost as if they are fitted to the wrong end?
Shape of the rear one looks similar to those I made for the fronts?
Make sure you have a nice warm environment for fitting the film as it needs to be flexible.
You can also put
~original
behind jpg and the photo is visible again
Hi
Finally got around to fitting this clear protector kit I got off eBay. Well worth it to protect the vulnerable stone chip areas on a 993. I had to reshape the front ones as I didn't like the fit, but the rears are good. However, the rear ones don't go right inside the PU, so I added a couple more cut pieces. Overall, at £19, not a bad kit.
I need to drive it now!
Looking good there.
Did you just stick them on dry? Must be tricky.
(And very brave to fit them in the cold weather; I think I did mine on the hottest day of the year)
kerb scraper said:
Looking good there.
Yes, did dry. Just used the hair dryer to heat them up first so that they would stretch a little.
kerb scraper said:
Looking good there.
124,629
1,442,263
49,073
Ors97
