Torque settings
Tim996c4
15 Nov 2016
48
Does anyone have the torque settings for numbers 7,9,12,13 on the attached diagram?
Thanks in advance....[/img]
From Bentley manual:
7 - 17 ftlbs or 23 nm
9 - Doesn't say
12 - Diagonal brace to body M10 - 48 ftlbs or 65 nm
13 - Diagonal brace to rear cross member M12 - 82 ftlbs or 110 nm
With 9 I'd say take an educated guess based on the above.
Thanks both. Found the manuals but as you say, 9 doesn't appear to be listed. Any suggestions?
Sorry for the late reply ..
Diagonal brace to body M 10x1.5 65 nm / 48 ftlb.
Diagonal brace to cross member M 12x1.5 110 nm / 81 ftlb
Diagonal arm to carrier side section ( collar nut ) M10x1.5 23 nm / 17 ftlb
Thats all that is listed , there is nothing for 9 but you would go with the bolt size for the torque .
Cheers demort. 9 and 12 are the same part number, so I guess the same torque value will be about right....
Yes they are the same.
9 is Cross member at front to carrier side section.
12 is diagonal brace to body.
Both 65Nm according to the workshop manual I have.
Thanks MC. Wish they'd use the same names in the manual as they do for parts!
The Knowledge Gruppe book (p121) also says 65 Nm, as MisterCorn pointed out.
exhaust manifold - K nut torque setting
I have the PPBB titanium stud kit about to be fitted to my 996 Carrera.
I have found the torque setting for the standard bolts is 26Nm (19 ft/lb).
When using K nuts as supplied with the kit what torque setting should I use?
124,626
1,442,231
49,069
jdowrick
