I couldn't do it on my '98 C2. As soon as I turned the key in the lock (either way) the alarm went off. It didn't happen very often though, as I seldom left it for more than 5 days. I learned to be quick.
On my Turbo, it's no problem, as I get the 10 seconds to turn on the ignition, or I can unlock/lock with the key to wake it up and then use the remote - AS MATHAMB SAYS.
Mine is only a Sunday car so always left for more than 5 days.Ii just put the key in the drivers lock and turn it anti-clockwise, as though i was locking it (nothing happens as its locked) and then remove key and just unlock in the normal way with the key fob :thumb:
On my '98 the alarm goes as soon as I turn the key either way.
Like someone else said, I've leaned to be quick
If I'm going to leave the car for a week, I usually remote unlock + lock it to stop it sleeping, I don't have battery charge problems, but I rearely leave it for more than 10 days.
I know this has been discussed a thousand times, but just want to clarify.
On my early 98 C2 I don't believe there is a way to wake from sleep mode without the alarm going off.
I've tried the technique of turning the key anti clockwise, then pressing the remote but that doesn't work.
When I unlock on the key I don't get 10secs before it goes off, the alarm sounds straight away and keeps going until I turn the key in the ignition.
Based on other comments I think this is normal for an early car but just checking.
I used to leave it unlocked in the garage to avoid it happening but got a bit nervous about whether the Insurance company would pay out if it was stolen!
There is a bit of a legend that the early 3.4 RHD cars may have been wired incorrectly from the factory (or rather failed to be re-wired).....
i.e. its only the drivers side door that allows 10 seconds after the door lock mechanism is rolled back, in which to insert the key in the ignition and prove it was intentional
...theory is that it was overlooked that the drivers door isn't always the left one and the car actually thinks its the passenger door that has been breached - cue alarm going off full blast
Someone mentioned that it would be relatively simple to resolve this via the connections in to the control unit.... but not sure of the truth of this, or if anyone has actually done this to resolve the issue
On my 98, if I open the door after more than 5 or so days I just get straight in it and start it up and the alarm stays silent. I always keep it on a CTEK 5 battery conditioner too. Recently, during the very cold weather, keen to take it out for a Sunday breakfast meet, I somehow managed to break the drivers door lock mechanism that resulted in an expensive factory order replacement
Ha! That's a really interesting legend, and would eplxain why some people didn't have the problem.
Does the passenger side have a physical lock? I don't remember, would be easy to test if so.
