My car is a 996 C2 and nearly three years old. I've owned it from new and never tracked it or abused it.I've had the RMS replaced twice so far and for reasons best known as 'esp' I thought as it's due a 3 year service/MOT next month I'd have look under the back and see if there was any evidence of oil......And there it was
I'm covered under the warranty so Porsche will do the biz I guess, but I've only covered 5000 miles in the last year and should I expect this every bloody year?There is obviously a problem with these seals based on the number of threads on various sites etc.So what do I do?Do I chuck my toys out of the pram or just accept that this is part of the 'ownership' of a modern 996?Will this issue also have an effect on the re-sale value
It already is an issue that affects the value of the car. Unfortunately to many people accept this as part of 996 ownership because they have a warranty and don't care that it is poor quality engineering.
In some ways the 996 is akin to the 964, an unwanted offspring, won't use the term cause Sundeep will ban me :wink: )brought in to shore up a gap until a better model is manufactured a la 993 and now the 997
I wouldn't accept it. If you bought the car from new and have a relationship with the dealer have a chat with the manager at the dealer. Be nice and ask what he can do for you. They might offer to trade you to another car for no cost! Well probably not, but you never know your luck. :wink:
From my knowledge of RMS technology [not Porsche I hasten to add], they usually start weeping oil due to an increase or rise in crankcase pressure, as the piston rings 'bed-in' and the combustion pressures are allowed a little more past the piston rings and not a mechanical or construction failure of the seal itself - well certainly not at the mileage that guys on this forum are experiencing.
Possibly the indies are working on or have figured a fix by improving the crankcase eduction design. i.e. making the crankcase breather or ventilation better. A lot of engines have suffered similar problems as the manufacturers strive to make old designs comply with ever tighter emission regs - Euro 1V & now Euro V.
The RMS issue is the seal itself and the design of the engine in that Porsche are on to about the 5th modification and there is now a new tool released to fit the seal about another 5mm further in. The main problem is the manufacture of the liners which crack and this results in major engine failure.
Of course this is all conjecture because there is nothing wrong with the M96 engine which just happens to be used in the Boxster/996/997. So go figure if a manufacturer will admit there is a problem when this is the engine that they use across their entire range of sports cars.
Quote: Originally posted by Shed17 on 26 April 2006
The RMS issue is the seal itself and the design of the engine in that Porsche are on to about the 5th modification and there is now a new tool released to fit the seal about another 5mm further in. The main problem is the manufacture of the liners which crack and this results in major engine failure.Of course this is all conjecture because there is nothing wrong with the M96 engine which just happens to be used in the Boxster/996/997. So go figure if a manufacturer will admit there is a problem when this is the engine that they use across their entire range of sports cars.
indeed, tracking a car seems to have no bearing on the position..... as there are still enough cars out there without the problem...
but compared to other manufacturers we seem to be still doing well for overall reliability, at least it's not like TVR where they (not usre if they still) make you sign an agreement when buying new that you accept the car is hand made and thus can break down, etc :?
although at this point some wise words from Mark Pearce is needed who knows a bit about RMS !
Talking of Mr Pearce, where is he? Not seen him around for a few days - hope he is well and PAG have not visited him or put a gagging order on him because of the warranty words on his web site.
Ala the latest design of GT3 RMS is a modification comes with a new crankcase breather system, (from PMS) worth an extra 5/8hp and so far no reported failures!!
If they're bringing out a tool to push the rms in to the c/case a further 5mm then that has shades of accelerated crankshaft wear area and they want to push the seal in to ride on an unworn area of the crank. A popular fix for other engine manufacturers is to fit a wear ring onto the crank end and install a new seal with slightly higher lip tension and/or different material. Although it has been known for oil to weep between the crank and the wear ring.
I know about the cracked liners and the leaks from the intermediate shaft & enjoy reading the engine rebuild articles in 911 & Porker Wurld.
Daz, do you think maybe I should send my c.v. to Dr. Ing h.c. F. Porsche AG??? Sounds like they need some help in the engineering department!
