madaboutmx5s
- Joined
- 5 Mar 2023
- Messages
- 21
Got my C4S back from Nine Excellence today after having the following work done.
1. Replacement over the gearbox brake line done and brake lines to rear calipers. As mentioned the over the gearbox line had been done (but badly) so replaced with new genuine parts.
2. Whilst the gearbox was out I had the IMS checked to make sure it had been done as per the service history, which came back as correct and it has an LN Engineering version fitted.
3. With the gearbox out it was noted the RMS (whilst it had been done when the IMS was done about 18 months ago) had a weep so maybe pressed in badly. As such I got a new RMS fitted.
4. With all the above done it was noted a prop shaft flange was worn so had this replaced with a new part.
5. Finally I had the AOS done as there was no history of it being done. I dont know if related but the car had idled about 900rpm and would stick occasionally at 1k rpm. With the above work done the idle has dropped to about 800rpm.
I will have to ask Nine Excellence if they reset the idle or if a wearing AOS could cause the symptom I mention above with idle.
