I have a CTEK but currently at my new place dont have space to put the 911 C4S in the garage.
This time after only 8 days and the battery died.... so I think I need an interim approach to keeping (now probably a new battery) fully charged while it doesn't have access to the garage.... hence the solar option.
I've been looking around and reading up and think to be safe something around 5w+ would be great, but the problem is they start getting REALLY large.
I found a 6w from halfords that has great reviews (Halfords Solar Battery Maintainer 12v 6W) and just wondering if anyone else has any comments on this (There's also a 2.4w but I don't think that'll be enough to maintain the battery)?
Also they have an OBD adapter for this to use that for charging, but I believe on a 03 996 C4S that the cigarette lighter port is live?
I bought a rectangular solar panel charger off eBay for about £14 to put on my Audi when I was overseas. Left it on a car park for 6 months with the panel on the dash. Started a treat when I came back for it :thumb:
Oh wow that's still way cheaper than the halfords one. Quick question, does this one have an indicator that it's doing something when plugged in.... Because the halfords one doesn't which bothers me. Would be nice to have some peace of mind while away.
You're right battery was completely gone, had an issue with a cell. It wasn't maintaining a charge or even charging properly. Saw on the race diagnostic. We charged it and after a bit it still wouldn't start on its own. I just replaced it myself with a larger battery..... Now I just need a solar charger to not mess up the new battery and keep it topped up.
I purchased this, Oxford WeatherProof Solar Charger. I have used it since April this year and car has started first time every time easily.
Longest I have left the car for is ten days.
You can also purchase extension leads to extend the range from car to panel placement.
Thats great!!! Thanks for the info. Also do you happen to know how many watts this is? Seems quite large so is hopefully around 6, but the ebay listing doesnt say.
Martian said:
We're pretty limited on sun at the mo, and it will be Winter soon!
Yeah I was thinking that too, on a positive my car faces South so if I get a larger panel around 6W or so it should be sufficient during daylight to keep a good battery at least topped up. I agree I'd be pushing it with a smaller panel.
10 days isnt too bad at all really, A few times I've left my car 3-4 weeks without being on the trickle charger (by accident) and it started right up. Guess the issue is once the battery is drained a couple times things go downhill really fast.
I use the Xenta 13w briefcase charger which comes with a regulator. I bought it on special offer from ebuyer.
It fits in the rear shelf when the car is parked and is enough to keep my battery toppped up.
I use the Xenia 13w briefcase charger which come s with a regulator. I bought it on special,offer from ebuyer.
Yes the cable is long enough to reach the front lighter socket.
You have the right one.
It will fit at an angle in the rear shelf, just propped up over the seat backs, or you can cut off the lower edge where there is a cable recess and this makes it exactly the right size to fit flat on the shelf tucked in behind the seats.
Just want to follow up with this for anyone reading in the future.
Still have to clean out my garage so I've been using this since the previous post.
I have to say this solar panel is awesome!!! Left my car a couple weeks almost and zero issues.
As mentioned this will fill the back shelf just over 3/4 of the way, but with that you get a bigger piece of mind knowing that it can keep a healthy battery topped vs those smaller wattage ones.
