Robbie,
That steering wheel will fit a gen 1 and you will need the 997.2/991 airbag for it
the steated wheel will only work if you have heated seats in your car if you have then there is no reason it wont work .
You will need the newer steering control module they are about £230 and you will need to get your opc to turn on the multifunction option through piwis even thought you dont have MF if still needs to be turned on to make the horn work. you must insist at the opc they do this as they think they know better, and they dont. also from the pic it looks like you might be missing the springs that make the airbag/ horn return when you press it they are only a few quid at the opc you cant use the gen1 ones they are too short.
good luck sorting it and funny I always tell people the steering wheel change mod is about £1000 and by the time you have the new module that will be where your at . dont forget to make sure the wiring loom is in the grove for it as you slide the airbag in also apply a small amount of silicon grease around the edge of the airbag this will help stop it from sticking. :thumb: :thumb:
