hinge bushes (4xbrass inserts) are worn on my drivers door and I will need to remove the door completely to replace them. I can do this two ways: remove the 6 hinge bolts or knock out the two hinge pins.
The 6 bolts would be easier and less likely to damage the paint, but I imagine lining the gaps up after would be more difficult.
Any one removed and replaced a door on a 993? Any advice as to which method works best?
I will probably have to do it singlehanded, but i shoukl be able to set up some suspension sttaps and jacks underneath.
JanP
