easternjets said:
wasz said:
I would go with conventional ceramic floor tiles. much more durable.
Apart from: They are lethal when wet. Are freezing cold to walk on as opposed to plastic tiles that are not. Plastic tiles can be lifted if moving house. Plastic tiles can be lifted if damaged and replaced with a new one in 5 mins. Ceramic tiles can crack if jacking up heavy weight and can crack if heavy tools are dropped on them. They do look good, so if you want style over substance then go for them.
The comment about tiles being lethal when wet is slightly misleading as it's a case of right tiles for right application. For the garage you need external tiles which have a non slip function to them. For those who use their garage just to store their car and associated bits and pieces, then tiles are fine. If your garage is a workshop then it's worth the step up to resin.
The heat deflection along with water getting under the plastic tiles when you drive in with a wet car would do my head in. But we're a broad church, each to their own.
