Hi all,
I am new to 911uk.
According to man maths I will be in the market for a 996c2 or more specifically a 996csr from rpm technik in around 12 months. However, I have a single garage that is only 2300mm wide inside. The car will fit but..... will I be able to get in and out? I am pretty slim and again, according to man maths if I park closer to one side of the garage, put some protective foam on the wall and have the window down I should be able to get in and out.
Is there anyone out there who can confirm this to be fact or fantasy?
If it helps I get out of with a 400mm gap between car body and wall and I'm not that agile. Sometimes I put the seat back. I have carpet on the wall i open the door into.
I think standard 996 is 1770 wide (1830 with mirrors).
Mine is 2570mm at the narrow point where (sods law) I need to open the door. I have a 30mm thick piece of polystyrene there and it's a pretty tight squeeze getting myself in and out. I could probably gain another 50mm parking closer to the wall on the other side, but it would be squeaky bum time every time I backed the car out.
So my guess is no, 2300mm is just too tight for comfort.
I'm sure you've considered it, but the constraint on my garage is the door opening. I've already replaced the up and over door with a roller to lose the wooden frame and gain a couple of extra inches both sides but it's still relatively tight with the mirrors folded out and I'm too chicken to reverse out with them folded in!
Bulldoze it and build it twice as wide as what you have now. My garage is 6.2m wide and I still could use another 1.5m for both driver and passenger to both get out comfortable with both cars in.
I have one level with my driver door and another chopped up to "clad" the brick plllar level with the passenger door (for piece of mind) i.e. I have "touched" the corner of the car while reversing in (once!), which wasn't pretty...
My garage is only a single and the C4S went in fine but the hips were a little snug going through the actual door....Getting in and out is a bit of a wriggle but wouldn't bother me being a occasional weekend car....If I was getting in and out everyday that would be a different story and would become annoying very quickly!
Fitting a roller door in place of an "up and over" should give you more room on the way in, as they mount to the rear/inside of the brick face, rather than involving a wooden frame inside the aperture
....still on my to-do list 3+ years after moving in to my current house....
