Also tried out this universal splitter I had, the car had a small lip spoiler from aero kit but this is wider. Not the best close up if I'm honest but I'll see what its like.
Inner Sills all coated with cavity wax along with the seam and lower section on the rear arches. I coated rear arch pieces with stone chip as well. Was going to leave the arch trim off but refitted and will remove to wash it out after 6 months for a look.
Wheels arrived today out of nowhere, they had appeared to have been lost.
Rushed home from work keen to check rears and they fit, just. Tyre has a very small poke but I'm fine with it. Fronts I might get away with 15mm spacer to even out track increase as much as possible but I'll try 9mm to start with.
In the house getting waxed at the moment.
There 10in et40 so low offset for narrow body. Fronts I have 15mm spacers fitted to even out track increase a little. No scrubing when I went for a quick drive earlier over some bumpy back roads.
