Dash light bulbs
Delanor
Nurburgring
1 Oct 2016
440
Has anyone successfully changed the OE Dash light bulbs for something a little brighter/clearer - maybe LED`s?
Del.
I haven't yet, but I need to take my dashboard out as the odometer bulb has died. Removing the dashboard is really easy to do fortunately.
Do a search, I'm sure there was a thread on fitting LEDs.
be really careful with the ribbon pcb when changing the bulbs, on mine it had become really fragile with age and a couple of the tracks broke and they are not cheap to replace
I changed mine for white LEDs a couple of years ago. It wasn't that tricky but I hated it and changed them back.
It's not too difficult but take care as they say above. Also, I seem to remember it is easy to mark the leather on the dash console if you're not careful.
I guessed that White maybe a bit too much so I was going to try Orange/Yellow LED`s to brighten it up a bit.
Del.
Del.
Yes - that was the problem. Am sure you can find something to please your eye but I found white to be too bright and too `modern`.
There are a few posts on rennlist that cover this with pics I think?
Alun
I went for three colours, bit like a golf I was in years ago had red and blue, I went to white for speed as the red was too dim during the day.
Are they all T5 bulbs just a different wattage and how many is there to change?
Del.
There are three t5 for the mile/speed/clock lights.
The speedo and tacho are t10 push in bulbs, make sure these are wide angle with the leds around the side and top
The backlight for oil and volts are again t5
so total 5 x t5 and 2 x t10
:thumb: Thanks - all has become clear I will get a selection of colours and see which looks best.
Del.
Could you post some pictures Of The options/results? My volts bulb is out but the whole lot are pretty dim on full blast so might go for a change..
Will do - if you change the dash bulbs to LED`s do they still dim down on the dimmer button?
Del.
yes LEDs dim, but to fair at full brightness they arent bright
124,617
1,442,145
49,050
N13LVV
