Those of you who have had a new IMS bearing fitted to your 3.4s, could you please tell me what bearing you fitted and where you bought it please?
Also did it come as a kit with end cover or did you buy just the bearing? If so did you get the cover from Porsche?
This video from Pedro's garage shows well the issues and I'm pretty impressed with the direct oil feed bearing.
http://youtu.be/hzUq2DFpeKw
However I'm happy to fit a traditional style un-fed bearing as I'll only be doing 2-3k miles a year so even if I change it every 20k miles that'll be 7-10 years time.
So let me know what you've all been fitting please so I can decide.
I've seen the SKF bearing for £25 or so but has anyone actually fitted it? I'm guessing it's the wrong width so needs a spacer to take up the shortfall? Also it comes back to where do I get the cover from if I source just the bearing?
One final thing, I'm aware of some scaremongering suggesting that they shouldn't be pulled in situ. I'm not convinced.
One of the arguments is that it pulls on the chains, yet the bearing pullers I've seen simply anchor against another part of IMS shaft. They aren't fixed onto something else in turn yanking away at the shaft and chains. It's a bearing and a hole for said bearing. Not rocket science.
I'm a precision engineer producing subsea oil and gas components including bearing housings etc so do have an understanding of them to an extent.
I don't want an argument about whether I should change it, I would just like to hear what bearings you've been fitting, so let keep it friendly.
Thanks!
Thanks!
