What did you buy your 993 this week ?
cont.
Weight Saving & Horses Released, so a Win Win in my Book..
Top Tip, remove the Fan Shroud and attach to the Bypass Pipe, then install the two together.. Way easier.
OBD
Had my OBD reader from Tore delivered last week. Pleased to report only 3 codes all for air-con flaps and motor as I'd expected. The tool makes it very easy to fix specific problems. A great addition.
is there a custom set of titanium exhaust bolts that anyone makes which fit the 993 by any chance!?
- All original Porsche shifter linkages and plastic bush
- Clutch master cylinder
- Double relay blower
- Distributor cap and rotor
- Oil pressure sensor
MOT.
Oil, oil filters, sump washers, brake fluid, rear brake pads, rear brake discs, brake pad wear sensors, anti squeal shims, gearbox oil and air con re-gas. Plus a set of Tore B led's for the panel in front of the gear stick as a couple of the lights have stopped working.
Fitted new front screen outer seal, bargain off eBay, genuine part 99354192500, £40 delivered, awaiting delivery of front bump stops and dust covers from the 'Homeland".
I, like many in the South of the UK this weekend, took advantage of what felt like the First Day of Summer [!] and washed the Pig in the glorious Sunshine.. Aqua Waxed 'n' all.. 8)
Finished hunting for a GT3 and following completion of front ARB refurb with a recoat and a new set of bushes and clamps, new drop links and a clean up.
I took delivery of a new set of Beru leads, dizi caps, rotors, bonnet strut and a set of wipers of all things.
Stripped out the top and bottom of the engine for access to the leads - fun begins tomorrow - ***** it's mother's day...
Maybe next week then :floor:
Not sure I'll mount this to the 993 as a permanent feature, but had some [stressfully patient!] fun with an exact Arctic Silver colour match wrap on the Rear Centre Section..!
Very RUF I thought.. 8)
What do you think..?
911livin said:
PSS10, RS top mounts, drop links, control arms, replace all bushes :D
Do you have a photo of your RS Top Mounts..? Been thinking about these for my 993..
http://911uk.com/viewtopic.php?t=132797
124,627
1,442,205
49,058
GoochyTM
