The value of mesh
Beej160
29 Nov 2014
340
Hi guys
Just wanted to check the space behind the front grilles since DIY mesh 1.5yrs ago.
Not even a tiny stone did I find behind the grilles!
Sorry if the pics are sideways :pc:
Nice, I've not checked mine yet but hopefully I will find the same.
Wow! :eek:
Really must fit some, after 2 years my air con rads are battered with no mesh, still working though, for now. :D
I replaced one of my AC condensers recently due to leaking, shall do the other side and both coolant rads and maybe add a centre rad too in the next few months... And add some mesh at that point!
Good result.
I've just done rads and condensers but didn't add mesh as I like the standard front bumper openings and the car does low miles. I think I may add some though to protect all of my hard work.
JS1500-
Read up about 3rd rads before you spend your hard earned cash.
Hartech say -
"I have no problem with anyone fitting a third radiator if they want to but so far our tests suggest it is not an important factor."
Thread here -
http://911uk.com/viewtopic.php?t=89494&postdays=0&postorder=asc&start=20
The above is about 997s but I'm guessing the principle is the same?
Either way read up a bit. I've fitted an LTT, but won't bother with the 3rd rad.
Apologies for thread derailment OP. :thumb:
Which kit is best without having to remove or cut the OE plastic grills?
I know you can make your own but I would also like to do this but using a pre-made kit.
Don't buy the Rennline kit, it's easier to make your own as the mesh is badly shaped and difficult to bend! Zunsport looks good but it's a lot of money, it was my first choice but Design911 didn't have it in stock. Design911 now have a cheaper kit but it's still expensive, I can't comment as I haven't seen it.
Thanks Maldren. I thought with the Zunsport you had to remove the plastic grills, someone did mention a kit which you can attach and leave the grills in situ??
Marky911 said:
Good result.
JS1500-
Hartech say -
Thread here -
Thanks for the input Marky. Maybe I won't bother with the centre rad... I do have a LTT and new water pump waiting to go on too...
It costs about £15 to do yourself and is really quite easy.
What mesh did you use, Graeme? Sorry if covered elsewhere...
I bought black aluminium mesh off Ebay, easy to bend and very cheap. I used stainless screws to fasten the mesh to the back of the spoiler.
124,621
1,442,166
49,052
Ravioli
