Hi
It's a long story, but to cut to the chase I cut the wires to my old (pre cat) o2 sensor (2003 car) while the engine was running. I got a healthy spark as I did so.
What damage have I done?
The longer version of this is that I replaced my RHS CAT section because of a blow that I just could not fix satisfactorily despite extensive welding. So I got a nice secondhand one, with o2 sensors attached and fitted that. I should have freed the o2 sensors off but I did not. Of course the pre cat (bank 1, 1) sensor gave a fault, no activity P0134. So its seized in properly and wont come out despite the advice of several you tube videos and bending of 2 quite strong 22mm crows foots. Thats when I stupidly cut the wires with the engine running. I was trying to keep the exhaust hot. Out comes that section of exhaust, and after a fight the old o2 sensor is out. So I remove the (known good) o2 sensor form my previous CAT and fit that.
Sure enough I have the same code P0134. And yes of course I have reset it. More than once. Can heating it with a butane torch when I removed it have killed it? Any fuses to look at? C2 30A looks good.
So what is my next step forwards? I was under the car with a multimeter this morning, but water dripping in my ear and the whole situation and meaningless of all the numbers and confusion of which pin is which caused me to give up.
You can tell I am just awful at car electrics. The car drives just fine by the way.
Any advice appreciated.
Berni
Berni
