Mac68
Nurburgring
- Joined
- 11 Mar 2021
- Messages
- 378
I purchased this 997.1 in March 2021 and so far I'm VERY happy with it, I love it in fact. I fancied a TIP, which is not a hugely choice but for me it's ideal. Here's my intro thread. http://www.911uk.com/viewtopic.php?t=144581
I had a PPI carried out by Anthony at Porsche Inspections, very thorough and a nice guy to deal with. I was a nervous buyer but he was helpful at explaining the importance, and how to tackle, the issues he'd found.
The previous owner the car had an engine failure at 80K, about 4 years ago, and opted for a full Hartech rebuild. The rebuild consisted of 6 Nikasil liners, 6 reconditioned and uprated pistons with new piston coatings (not sure which coating), new larger IM shaft and bearing, new crankshaft bearings, all new timing chains, cylinder head skim, which was apparently pretty much the full monty from Hartech, at the time.
I set about tackling some of the PPI items, as some are must do's. I researched a lot of garages and plumped for AMS Porsche in Hitchin. I got an excellent service and think they're a great company to work with. We agreed all the costs in advance and they photographed the car at various stages. They kept back some of the pars for me as I want to have a tinker with them or keep them as emergency spares. AMS offer a Saturday Surgery, where you can get the car on the ramps with the mechanic, have a natter and figure out the "must do's", "should do's" and "want to do's". The car needed quite a bit of work doing, which included a major service, brake fluid, engine out coolant pipes (ouch!), replacement mufflers (which I had fixed up previously as I intend to gundo them), a full TIP full service, new rear brake discs/pads, radiator fan, tandem pump, LTT, heatshields, plugs, coilpacks, oil pressure sender and new AC condensers/regas. I would have tackled some of these items myself as I like tinkering and learning but as it was engine out job it made sense. I intend the keep this car for quite a while and I'm sure I'll have the chance to do lots of jobs on it
AMS found that the RMS seal was made of silicone sealant. Obviously, a previous garage (Not Hartech) had bodged a seal instead of ordering and waiting for a new seal. I also had it bore score checked and thankfully it was nice and smooth/healthy.
Since then the car has developed a weird starting issue, where it cuts out after initially being started, when the revs drop to 700 and upon restarting there's a strong sulphur like smell. I suspect the cats at 125K are on borrowed time so I'm planning to get them replaced along with the failed O2 sensor ASAP.
Next up are my front shocks, which are a bit rusty near the tops and they're hollow PASM shocks. I'm considering having a go at doing this myself. What could go wrong! :?: probably lots of connected suspension parts!
I'm also intending to have a go at making some home made "jackstands", the type that wraparound the trolley jack and accommodate the puck. I'll probably put a small pivot on them to allow for the car to be up on one side only, which is required due to the width of my garage, again what could go wrong :dont know:
I'm intending to do the following at some point:
Refurbed rims
Tidy up underneath, ACF50 as I have a large bottle to use
Paint the calipers (black)
Gundo the exhaust
Slight rust on the wheel archers (a stitch in time)
Fix the drivers seat bolster
Spacers (on my old car this will inevitably lead to new wheel bearings£££)
Tackle the chipped paintwork
Braided brakelines
Tackle the centre console as the soft touch surface has gone.
Here's a recent snap for no good reason!
Refurbed rims
Gundo the exhaust
Braided brakelines
