Hi all,
Following on from a previous thread and as part of the winter upgrade plan I’m going to replace the steering column.
Problem is I can’t for the life of me get it out!
I’ve been upside down under the dash for a good hour but it just will not navigate its way past the steering angle sensor on the main steering column.
So I tried undoing the steering rack bolts and moving the rack to get a little more clearance but that didn’t help much.
I also tried removing the steering wheel / instrument cluster in a vane attempt to remove or at least move the top section of the steering column.
Has anyone any tips / advice ? Next step I’m thinking is to loosen the front subframe and see if that gives. Up enough space to facilitate the repair, though I feel I’m going too deep and certainly into unknown territory by doing so !
Thank you in advance!!
