duncanelliott81
- Joined
- 9 Nov 2015
- Messages
- 26
Hi guys and girls,
New to the forum so please go gentle with me!
I've recently bought a 2005 997 Carrera S and I've got a very annoying squeak coming into the cabin. It very subtle and only happens while the car is moving. It seems like air flowing through the car, makes a fan spin and subsequently squeak and squeal.
Things I have tried to fix it with no difference....
switch air con off
switch whole heating / cooling system off.
make heating fans go full whack
Whilst I feel like I'm hearing the noise through the vents....it clearly is not heater related! As I say, it seems like moving along makes the fan spin and make the noise. When I pull up to a junction....it stops!
Does anyone have any ideas? Which fan could be causing the issue and more importantly, is there a cure? Maybe I can squirt some lube at it and solve the problem....if just temporarily.
I've found a similar issue in the forums for a 964 but nothing on a 997.
Perversely, my oven makes an identical squeaking noise.....there is a fan knackered on that too somewhere!
I hope you can help me keep my sanity!
switch air con off
