Zingers, I am reluctant to pass on info without personal experience as there is so much fake news on the web, but as those readings matched that which you posted, also that DeMort had educated us in the past to the extent that just touching the door handle powers up the fuel pump into a prime mode and may bring other circuits to life, that along with my base level electrical logic suggested your charge rate might match expectations. Glad it hopefully reduced your concern.
Steve, no argument from me re your internet findings, just that mine differ.. :dont know:
Now that DeMort has posted PORSCHE based info, I take that as gospel. Of course it is best to remember that the on board kit can alter in spec with the passage of time thus model year or in some cases VIN number may make a difference in maintenance data required to service appropriately.. :?:
I suspect your non O.E. battery will be fine, though I would be keeping a weather eye on voltages for a while till I became comfortable that there were no issues arising.
Me..? After many years of minimising costs on parts for all the vehicles I ever ran other than Porsches on which I ever stuck to O.E. parts given the quality difference in the days of air cooled.
These days I am not as impressed by Porsche engineering as I was back then, though having typed that, such is the complexity of the on board systems that even in the case of a battery I prefer to stick with O.E. to avoid complications. Also as my 991 is under the extended warranty scheme, I prefer to avoid giving Porsche an out should I be in the unfortunate situation of having to make a claim.
One other thing Steve that might be worth considering relative to the 12.6 volts at REST... Generally in times past, to measuring battery voltage as one means of attempting to determine it`s condition, the measurements would be made with the battery disconnected from the vehicle, and not having been on charge for at least 30 mins, thus avoiding the chance of some circuit or other drawing power, and that if recently taken off charge, the battery voltage would have had time to settle somewhat and thus avoid creating a false determination of condition when using voltage as a measure.. :?:
I am well out of touch, and modern vehicles seem to ever have the possibility of some device being in circuit drawing current, and given the difference in voltage may only be in tenths of a volt when attempting to make determinations of condition, it seems a simple matter to get it wrong.. :?:
All that typed I think it is perhaps simpler if not a prerequisite to go with specific vehicle data if available. :?:
