I wanted to be able to reach the rear crossmember on my 996 turbo, and took the following measurements:
- Ground to bottom of side skirt (at rear jacking point): 9.5cm
- Rear cross member to rear of car: 90cm
- Ground to bottom of exhaust silencer: 14.5cm
In the end, I went for the Weber WDK1.3 HLQ / WDK13HLQ, which is identical to the AC Hydraulics DK13HLQ model recommended by Pelican parts for jacking up a 996. It was quite expensive, but is a fantastic bit of kit - very low with a very long reach.
Some measurements of that and other jacks I looked at follow...
Sealey 2200HL (£275):
- Minimum Saddle Height: 80mm
- Maximum Saddle Height: 805mm
- Maximum Chassis Height: 220mm
- Overall Length: 950mm
Sealey 2000LEQ (£206):
- Maximum Saddle Height: 375mm
- Maximum Chassis Height: 92mm
- Overall Length: 860mm
Sealey 2000ESLE (£324):
- Minimum Saddle Height: 75mm
- Maximum Saddle Height: 520mm
- Maximum Chassis Height: 135mm
- Overall Length: 960mm
Clarke CTJ1500QULP (£179):
- Minimum Saddle Height: 72 mm
- Maximum Saddle Height: 607 mm
- Maximum Chassis Height: 240mm
- Overall Length: 880mm
Weber WDK1.3 HLQ / WDK13HLQ (£423):
- Maximum Saddle Height: 735mm
- Maximum Chassis Height: 160mm
- Overall Length: 940mm
