The newer models of Cayenne and Macan with glass roof have a drain tube at the rear each side ...
I've seen several of these block over the last few years .. the drivers side has the radio amp fitted just where these leak if blocked , about £1K to replace .
To see if you have these tubes then as per pictures or if you prefer .. look up each side from underneath in the corners above the exhaust .
On a service these days .. i cut the end back with side cutters .. or you can do as per images and pull the pipe out , cut and refit .. use lube to refit though .. wd40 will do .
Images of the rotten wiring that also needed replacing .
